p15353
Feb 25, 2020Initiate
RBK50 and Vodafone Gigabox
Hi there I have just ordered a RBK50 (its on its way) to install with my Vodafone Gigabox However, I have been advised that VOIP service I have will ONLY run when connected to the Gigabox ...
Feb 25, 2020Guru - Experienced User
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Try option #2 if your modem has a DMZ or IP pass thru so you can run the Orbi in router mode and keep the features needed.
- p15353Feb 26, 2020Initiate
Thank you
Do i meed to turn off DCHP on the Gigabox to retain parental control;s etc on the Orbi , which yuou said to run in router mode? Note I need VOIP connetced to Gigabox
- FURRYe38Feb 26, 2020Guru - Experienced User
If the VoIP has to be connected to the Main ISP Gigabox, then you'll probably need to leave DHCP enabled there.
What you might try is this, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
