p15353
Feb 25, 2020Initiate
RBK50 and Vodafone Gigabox
Hi there I have just ordered a RBK50 (its on its way) to install with my Vodafone Gigabox However, I have been advised that VOIP service I have will ONLY run when connected to the Gigabox ...
Feb 25, 2020Guru - Experienced User
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Try option #2 if your modem has a DMZ or IP pass thru so you can run the Orbi in router mode and keep the features needed.
p15353
Feb 26, 2020Initiate
Thank you
Do i meed to turn off DCHP on the Gigabox to retain parental control;s etc on the Orbi , which yuou said to run in router mode? Note I need VOIP connetced to Gigabox
