Jpetrarca4
Dec 24, 2018Aspirant
Rbk50 blocking firmware update
Hi guys. Wondering if anyone can help. My system frequently reboots on the latest firmware. I went through and did the telnet steps to block the auto update. I downgraded the firmware and all was well...
ekhalil
Dec 24, 2018Master
What type of wired devices do you have connected to Orbi?
Try disconnecting all your wired devices and see if the reboots will stop.
If that helps then start adding the devices one by one.
- Jpetrarca4Dec 24, 2018AspirantMy desktop computer, wink smArt home hub and philips hue hub. I’ll give it a shot
