Moneypit
Jan 04, 2021Aspirant
RBK50 blocking sites
HI i have an RBK50 which seems to be blocking explicite URL sites, in particular my companies mailbox server.. I have disconnected the Orbi from my ISP CPE and connected directely through the ISP CPE...
Jan 04, 2021Guru - Experienced User
Have you tried using the gateway in router mode and putting the orbi in access point mode?
You loose some features on the orbi
Moneypit
HI I havent tried that but was under the impression i would loose my seamless roaming as we use the orbi to provide mobile coverage over wifi ..
Was hopibg there was an explination as to why this just happened,,
- plemansJan 04, 2021Guru - Experienced User
having the orbi in access point mode doesn't disable seamless roaming. It'd still work fine. It just doesn't integrate with the ISP cpe router's wireless.
It could be a dns issue. Have you tried using googles at 8.8.8.8 or 8.8.4.4 or cloudfare at 1.1.1.1
- MoneypitJan 04, 2021Aspirant
It uses the ISP's DNS but could change the DNS In the orbi, the other reason i switched off the CPE was the interference i was getting on the 2.4ghz, which is what i use mosty as i have a lot of solid masonary in the house.. i ll try the DNS ...
You can always run the cpe in router mode with wireless disabled and use the orbi as the access point. I do this regularly with my orbi when I'm trying new routers or modem/router combo devices.
