jim45tn
Apr 17, 2019Aspirant
RBK50 Cannot connect to printers
Have the Orbi RBK50 with two satellites. Network works fine. I had to go to a backup laptop while the main laptop is being repaired. I connect fine to the internet but cannot connect to any of my pri...
Apr 17, 2019Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings try unchecking the 5Ghz broadcast SSID. Apply then try to setup the printers.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- jim45tnApr 17, 2019Aspirant
The firmware version is 2.3.1.44. There is no modem installed- it is Fiber Optic.
I tried those changes but nothing has changed. The printers show up on the network but unable to see them from this laptop. Turned off firewalls and virus checkers and still nothing. Thinking of adding a USB wireless to see if the wireless card might be the issue.
- FURRYe38Apr 17, 2019Guru - Experienced User
Do they show up on other devices or PCs?
Sounds like something with that laptop then...
Yes they show up on ipads and iphones so I figured it must be something with the laptop. Strange thing is I cannot connect to the modem as admin even hardwired to it although I can with my iphone
