jim45tn
Apr 17, 2019Aspirant
RBK50 Cannot connect to printers
Have the Orbi RBK50 with two satellites. Network works fine. I had to go to a backup laptop while the main laptop is being repaired. I connect fine to the internet but cannot connect to any of my pri...
jim45tn
The Orbi is 192.168.1.1
The printers are ...14, ...21
The laptop is ...23
Iphone is ...9
CrimpOn
Apr 17, 2019Guru - Experienced User
With an address in the same network as the Orbi router and printers, the laptop should be able to access everything.
When you open a web browser on the laptop and enter 192.168.1.1, what happens? If you get an error message, can you do a screen capture and attach it?
- jim45tnApr 17, 2019Aspirant
Here is a screenshot of the page when trying to access the Orbi
- CrimpOnApr 17, 2019Guru - Experienced User
Wow. Have not seen that one before! One web site says that Google Chrome sometimes gets this and proposes fixes:
https://troubleshooter.xyz/wiki/fix-err_network_access_denied-in-chrome/
In fact, the top 20 hits are all in reference to Chrome. Guess now is a good time to ask which browser is being used?
- jim45tnApr 17, 2019AspirantUsing Chrome now but also tried Explorer. No different. Last time I used this laptop was using another router never had an issue. I’m going to try a USB network adapter on Friday when I get it to see if that might be an issue but since I can access the internet now I don’t imagine that’s it.
