jim45tn
Apr 17, 2019Aspirant
RBK50 Cannot connect to printers
Have the Orbi RBK50 with two satellites. Network works fine. I had to go to a backup laptop while the main laptop is being repaired. I connect fine to the internet but cannot connect to any of my pri...
Apr 18, 2019Guru - Experienced User
Something in this PC is blocking access. Be sure to also check for security add-ons or software that maybe inhibiting access to this address.
Try a different PC or laptop to check for access there and compare.
