Andrianp
May 21, 2019Aspirant
RBK50. cannot connect to wifi/internet for mobile devices after power outage. Laptops are ok
After a brief power outage, all mobile devices (all android based) in my network will fail to connect to wifi (wifi will have no internet). While macbook and attached computers can connect.
Thi...
May 23, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has all android devices been powered off then back and to see if they will re-connect?
Has a proper power OFF of the entire Orbi system for 1 minute, then back on then see if the android devices connect?
This behavior will continue for about 3-4 hours and then the connection usually will be restored as usual. I have tried to turn off all the router (Orbi is behind my ISP router on fixed IP) and turning it on again.
I am using channel 1 for the wifi, as it's the vacant channel in our environment.
This is driving me crazy as different behaviors were displayed for mobile devices and laptops. Is there a way to reset all t he connected devices to ORbi ???
Thanks for your help
