DPL-OZ
Nov 24, 2020Aspirant
RBK50 Can't detect device, no internet, intermittent access???
All of a sudden after 6 months of perfect function my Orbi RBK50 hardly works? I am in Sydney Australia and purchased this in April this year. MacOS setup, multiple devices connected, 2 Satellite...
Nov 24, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
DPL-OZ
When I could actually connect to the Router the Firmware was the latest version for non-USA.
Re size of home, we are metric so I have no idea what ft is? Nonetheless, I have 2 satellites and it all worked perfect before. The whole property had access over 700sqm.
As I can't connect / detect the router I have no way to answer your other questions and I cannot change any of the setup??.
