MobyDev
Aug 04, 2019Aspirant
RBK50 causing my CM1000 to power cycle
I have a Netgear CM1000 modem that’s been working fine connected to a Google WiFi system for over a year. I got the Orbi RBK50 system installed and it would cause my CM1000 to power cycle continuously...
- Aug 05, 2019
My solution was to move them about a foot apart and that seemed to work keeping the home phone connect from rebooting over again and again.this worked until I moved the satellite that room.
CrimpOn
Aug 04, 2019Guru - Experienced User
Continuously as in all the lights go off, it restarts by itself, and as soon as all the lights come on, it goes back off again? over and over? There is never a chance to connect to the internet?
- MobyDevAug 04, 2019AspirantKind of. The lights just all flash and then they turn off for a few seconds and sometimes the power light is the only light that comes on.
