MobyDev's avatar
MobyDev
RBK50 causing my CM1000 to power cycle
I have a Netgear CM1000 modem that’s been working fine connected to a Google WiFi system for over a year. I got the Orbi RBK50 system installed and it would cause my CM1000 to power cycle continuously...
  • Tjharris6's avatar
    Aug 05, 2019
    My solution was to move them about a foot apart and that seemed to work keeping the home phone connect from rebooting over again and again.this worked until I moved the satellite that room.
