MobyDev
Aug 04, 2019Aspirant
RBK50 causing my CM1000 to power cycle
I have a Netgear CM1000 modem that’s been working fine connected to a Google WiFi system for over a year. I got the Orbi RBK50 system installed and it would cause my CM1000 to power cycle continuously...
- Aug 05, 2019
My solution was to move them about a foot apart and that seemed to work keeping the home phone connect from rebooting over again and again.this worked until I moved the satellite that room.
Aug 06, 2019Guru - Experienced User
There should be at least 3 feet or more between the modem and any wifi router. They should never be in close proximity.
Tjharris6 wrote:My solution was to move them about a foot apart and that seemed to work keeping the home phone connect from rebooting over again and again.this worked until I moved the satellite that room.
CrimpOn
"Never" is such an absolute. My Orbi has been about one foot from two different modems for nearly three years and has never caused a problem. I would think that modem manufacturers should expect customers might place these items close together for convenience and shield the modem to prevent interference. "Good practice", absolutely. "never" seems a bit much.
- FURRYe38Aug 06, 2019Guru - Experienced User
Just because it works doesn't mean it's not doing something. Maybe however it's been good advise and good operationla standards in history not to have wifi devices too close to each other. Can cause problems. Users choice though.
