Boatmancalls
Feb 23, 2021Guide
RBK50 connecting to Vdsl2
I'm having a few issues with a recently installed RBK50 and how best to connect to the internet. Currently I'm using an old Netgear Nighthawk D7000v2 as a router (with the Wi-Fi switched off) and co...
vajim
Feb 23, 2021Master
Boatmancalls wrote:I'm having a few issues with a recently installed RBK50 and how best to connect to the internet. Currently I'm using an old Netgear Nighthawk D7000v2 as a router (with the Wi-Fi switched off) and connection to my vdsl line (Uk) with Vodafone as the ISP. Are there better routers that would provide a more stable connection?
I'm far from a networking expert but would appreciate any guidance/suggestions that might help.
My download speeds are varying between 15Mbps to 73Mbps.
IMHO...you aready have a 'better' router with the Orbi. The idea of running 2 routers and then add a Vodafone (?) only complicates the matter.
What firmware is your orbi running?
- BoatmancallsFeb 23, 2021Guide
Hi
i'm running version 2.7.2.104
I wondered if using both routers was the issue. As I said I'm a novice here, and tried using the Nighthawk D7000v2 as a broadband modem only to feed into the Orbi, but couldn't get the internet to connect.
- vajimFeb 23, 2021Master
Boatmancalls wrote:Hi
Running 2 routers can be an issue if not configured correctly as stated by my friend FURRYe38.
The firmware you have also has reported problems which you may want to consider rolling back. When did you notice your problems?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Part of the problem is I've changed so many things at the same time it's not easy to identify when the issues started. We have a much bigger bandwidth pull now than ever before with 3 simultaneous Zooms and Netflix etc. I suspect adding to the load. - and in all honestly am out of my depth in the IT stakes đ
I think trying to set the Orbi to act as an AP is a great idea and shall look at the link.
thanks again !
