Boatmancalls
Feb 23, 2021Guide
RBK50 connecting to Vdsl2
I'm having a few issues with a recently installed RBK50 and how best to connect to the internet. Currently I'm using an old Netgear Nighthawk D7000v2 as a router (with the Wi-Fi switched off) and co...
Feb 23, 2021Guru - Experienced User
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #1 as you can bridge the D series modem into modem only mode...
Boatmancalls wrote:I'm having a few issues with a recently installed RBK50 and how best to connect to the internet. Currently I'm using an old Netgear Nighthawk D7000v2 as a router (with the Wi-Fi switched off) and connection to my vdsl line (Uk) with Vodafone as the ISP. Are there better routers that would provide a more stable connection?
I'm far from a networking expert but would appreciate any guidance/suggestions that might help.
My download speeds are varying between 15Mbps to 73Mbps.
- vajimFeb 23, 2021Master
FURRYe38 wrote:https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATI think they are aware of the double NAT situation
- BoatmancallsFeb 23, 2021Guide
Thanks for the detailed reply. I will try a few options tomorrow and let you know how I get on
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #1 as you can bridge the D series modem into modem only mode...
đ
