JohnPhotography
Jun 27, 2018Aspirant
RBK50 Connection Issues
Hi. A few weeks ago, I began having issues with my RBK50 with dropping of WiFi connection with my laptop and iPhones.
So i updated to 2.1.4.16 in hopes of fixing the issue. Nope, getting th...
JohnPhotography
tucsontico wrote:
How many satellites does your system have? Did you update the satellites first, then the router? Try doing a factory reset of the router and satellites then reconfigure your system manually. DO NOT use any backup config files as they could contain corrupted info. After you've reconfigured your RBK50, allow about 5-10 minutes for the system to "settle". DO NOT use the built-in speedtest in the QOS tab of Advanced settings. If you wish to test your system speed do it through an online service or WiFi app.
I also recommend establishing IP address reservations for all your devices. Good luck!
I have one satellite. And yes, i did update the satellite firmware first then the routers.
I did do a factory reset, but i used a backup. I will do another and set up manually.
Also, how can establish IP address reservations for all of my devices?
Thanks!
Jun 27, 2018Guru - Experienced User
You might try a factory reset and set up from scratch and this time, don't use the back up config file.
