sujay265
Apr 16, 2020Tutor
RBK50 Coverage and Speed Buying Advise
Hello Everyone, I need your support for helping me to understand better, before I could by the Orbi RBK50 Wi-Fi mesh solution. I live in a single floor apartment with area of 3000 sq. ft, rectangul...
- Apr 17, 2020
What mode is your ISP modem/router working in? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopUnfortunately yes, 5Ghz will be effected by brick and concrete. Those are the worst. You may want to look into LAN connecting the RBS at a remote location so your backhaul over wired won't be effected by your building materials. https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
If you get the RBS connected via wired, yes. Easily.
sujay265
Apr 17, 2020Tutor
Hi Furry,
Thank you for your good answers. I appreciate it
1. Currently I am using a Huawei modem + wifi router (combined function) Model Huawei HG8245Q provided by the ISP. There is a fiber optic line from the ISP which plugs into the ISP provided Huawei HG8245Q and access the wifi from it.
2. The builting material is masonary brick block and cement and plastic plastering over it.
I am placing the RBR and RBS at a distance of 32 feet with 2 walls inbetween . Do you think the 5 GHz backhaul signal would be effective in my case with the given scenario?
3. My incoming speed from the IPS is 100 Mbps consistent speed, do you think i will get the same speed from RBS unit?
Kind Regards
Sujay
Apr 17, 2020Guru - Experienced User
Couple of options,
