JoeM845
Dec 28, 2018Luminary
RBK50 Daisy-Chaining and Intermittant drop-outs
I have one RBR50 in AP mode with a wireless connection to one RBS50 with the Daisy-Chain option unchecked. Intermittantly I get momentary drop-outs on a Pixel3 phone and an old LG tablet (both not mo...
- Dec 29, 2018
JoeM845 wrote:
I am not seeing what you describe. This is a very lightly-loaded network with only one RBS50 satellite. I have configured the 2.4GHz band to channels 11+7 and the 5GHz to channel 48.
JoeM845, this is what I mean. This is what I see in my network when Daisy Chain is enabled (this is from the built-in wifi scanner in my Macbook):
Once I disable backhaul only the Router Backhaul will be visible while the satellite backhaul networks will disappear. This is a proof that the Daisy Chain setting (on or off) is working correctly and not reversed.
ekhalil
Dec 29, 2018Master
JoeM845 wrote:
Thanks for your reply. My understanding is now that daisy-chain should not have impact (#1), but it does (#2) because of a bug in fw 2.2.1.210 (#3). You say that the GUI daisy-chain switch is accurate (#4) while other(s) -- with high guru points -- say it is reversed in fw 2.2.1.210. DHCP server log entries will show IP assignments (#5), but the DHCP server is not available in AP mode for good reason.
I changed the daisy-chain option to enabled (GUI) with no immediate change in behavior. I have not seen drop-outs yet, but I haven't exercised it much.
Activation and deactivation is working fine. You can see this by activating Daisy Chain and seeing the hidden networks from the Satellites using a wifi scan. This disappears immediately when you deactivate Daisy Chain. Satellites will never be able to connect to other satellites without seeing a backhaul radio network, so it's impossible that the Daisy Chain setting is reversed! ;)
The only issue in 2.2.1.210 that I noticed is that deactivating Daisy Chain in some cases affect the performance of Orbi.
Let's see, may be things will get better now? Hope so :)
JoeM845 wrote:
It would be nice if I could get log entries that show device associations/disassociatations instead of, or in additiona to, IP assignments. The undocumented log option "Wireless access" looked hopeful, but it either means something else (DHCP IP assignment?) or does not work.
Yes, I agree, that it will be usefull to have more events in the log like associations/disassociatations as you said, but also the roaming events.
JoeM845
Dec 29, 2018Luminary
I cannot discern a change in the hidden network behavior that corresponds to a change in the daisy-chain setting. In both cases Backhaul status on the "Attached devices" page shows "Good" and 5G. In both cases WiFi Analyzer (Android) shows the backhaul signals intermittantly on, but mostly off for minutes at time. A 2.4GHz ( channels 11+7) signal comes up. A little later a 5GHz (channel 157) signal comes up. Then they both drop. The 2.4GHz signal comes up alone also. The 5GHz signal comes up by itself sometimes, but less often.
Thanks for your time. I have tried to click on the Kudo button, but do not get any response.
- ekhalilDec 29, 2018Master
