tadslc
Aug 28, 2019Tutor
RBK50 Disconnects driving me crazy
I'm a somewhat older fellow that doesn't have the greatest grasp of modern technology. Just when I try to research the latest "get rid of cable" rave, I decide to update my WiFi router with what I t...
tadslc
Aug 28, 2019Tutor
This is what I'm talking about
been trying to log into orbilogin.com for 30 minutes with zero luck
WTF?
tadslc
Aug 28, 2019Tutor
I'm outside watching roku with a whopping 52Mbps link rate, looking at my iPhone with a 104 Mbps rate trying to use my Amazon Fire with a, get this, 1 Mbps link rate. I'm all of 15 ft from the satellite.
Of course all on 2.4G
- tadslcAug 28, 2019Tutor
Finally got into orbilogin.com and set my 2.4G to 75% and the 5 G to 50%
My firmware version is v2.3.5.30
I have been disconnected probably 5 times during this ordeal. I am now sitting 4 ft. from the satellite, only been disconnected once!
- Retired_MemberAug 28, 2019
tadslc wrote:Finally got into orbilogin.com and set my 2.4G to 75% and the 5 G to 50%
v2.3.5.30 has know problems
Did you do a manual update? If so, why?
IF you can't get this worked out with v2.3.5.30 installed you may have to stepback to the previous firmware.
Did no manual update, Orbi checked for updates when I installed
I also checked the Mimo and Beadforming boxes
