tadslc
Aug 28, 2019Tutor
RBK50 Disconnects driving me crazy
I'm a somewhat older fellow that doesn't have the greatest grasp of modern technology. Just when I try to research the latest "get rid of cable" rave, I decide to update my WiFi router with what I t...
Retired_Member
Aug 30, 2019Any progress on this?
- tadslcAug 30, 2019Tutor
Not really
Haven't done much since my last posts which I believe was Wednesday evening.
I played around with satellite placement last night though but really couldn't find anything that seemed to work any better. But the more I thought about it the more I'm thinking this isn't a satellite issue because when it disconnects averything disconnects.
I bought this system from Amazon as a refurbished unit and it wouldn't surprise me if someone returned it because of the disconnects. The upside is I have 30 days to return so I can still play around with them but since I'm just a somewhat computer illiterate guy, I'm running out of options.
One other thing that confuses me are suggestions on this post are often rebuttled by someone else so I have a hard time knowing who to believe.
- Retired_MemberAug 30, 2019
tadslc wrote:Not really
Good luck...I hope it works out.
In a open forum such as this, what appears to be rebuttling, is simply folks stating their opinion and hopfully trying to help. As a user, one must sort through it and decide which makes the most sense. Private messages to the ones offering the suggestions or to the community moderators is another option.
- FURRYe38Aug 30, 2019Guru - Experienced User
If this is a re-furb unit from amazon, and it's not working well. I would return it and either get something you know thats NEW if possible or go with something else. I've encountered this as well with a different Mfr router before with Amazon. There good and refunds and replacements.
Good Luck.
