SteveHansen26
Sep 10, 2022Guide
RBK50 DNS errors when sending to SMTP server
Latest firmware 2.7.4.24. When sending from Outlook or iOS clients, cannot send, error AUP-CXDNS. Shutting off wireless circumvents the issue. Any DNS setting in the ORBI that might correct this? Tha...
ekhalil
Sep 10, 2022Master
What DNS settings do you currently have in Orbi? Please check this in the Orbi web GUI (orbilogin.com) under >> ADVANCED >> Setup >> Internet Setup >>
- SteveHansen26Sep 11, 2022Guide
Have not changed from the defaults, so:
No Logon required
IP address assignment and DNS settings coming automatically from ISP, two DNS servers provided by my ISP
Default Router MAC address
No DHCP options
No VLAN ID specifications
No Dynamic DNS settings
I will add that errors occur whether connected via ethernet or WiFi.
- ekhalilSep 11, 2022MasterFor a test, please try to select “Use These DNS Servers” and set the dns servers to primary 1.1.1.1 and secondary 8.8.8.8 then click on Apply
Will do, though since that would impact the household working from home, it will be (much) later today. Thanks.
