YmeesYmees
Sep 30, 2019Aspirant
RBK50 Download Speed Issues
Just installed the RBK50 with Satellite. Running V2.3.5.30. Discovered a strange issue. If I run a speed test from my ATT modem (Fiber 1000), I get 900+ up and 900+ down. When I run the speed test fr...
Retired_Member
Oct 01, 2019
YmeesYmees wrote:Just installed the RBK50 with Satellite. Running V2.3.5.30. Discovered a strange issue. If I run a speed test from my ATT modem (Fiber 1000), I get 900+ up and 900+ down. When I run the speed test from the Orbi web ui, I get 900+ up, but only about 500 down. Any idea why this would happen?
How did you get V2.3.5.30. There are numerous reports of problems with this FW. Do a search. If the FW was installed auto as a NEW install see if you can find (downloads) a older version.
- YmeesYmeesOct 01, 2019Aspirant
I do not know how I got that version of firmware. It showed up in the app and I updated...- Retired_MemberOct 01, 2019
I do not know how I got that version of firmware. It showed up in the app and I updated...But my point is you DID NOT have to update
- YmeesYmeesOct 07, 2019Aspirant
Now I know... :-)
