YmeesYmees
Sep 30, 2019Aspirant
RBK50 Download Speed Issues
Just installed the RBK50 with Satellite. Running V2.3.5.30. Discovered a strange issue. If I run a speed test from my ATT modem (Fiber 1000), I get 900+ up and 900+ down. When I run the speed test fr...
Oct 01, 2019Guru - Experienced User
I found that at least for my 50 series, there seems to be a proble in FW, both old and recent in regards to the WAN to LAN not achieving anything near 900Mbps:
There have been mixed reports of some that are seeing near 900Mbps on the WAN to LAN side. Not sure if this is a HW issue or FW issue me and others who do see this. For speeds to achive anything near 900Mbps, HW NAT accelleration or Cut-Through is needed.
AP mode should result in seeing near 900Mbps.
Issue was reported to NG.
YmeesYmees wrote:Just installed the RBK50 with Satellite. Running V2.3.5.30. Discovered a strange issue. If I run a speed test from my ATT modem (Fiber 1000), I get 900+ up and 900+ down. When I run the speed test from the Orbi web ui, I get 900+ up, but only about 500 down. Any idea why this would happen?
