YmeesYmees
Sep 30, 2019Aspirant
RBK50 Download Speed Issues
Just installed the RBK50 with Satellite. Running V2.3.5.30. Discovered a strange issue. If I run a speed test from my ATT modem (Fiber 1000), I get 900+ up and 900+ down. When I run the speed test fr...
Oct 07, 2019Guru - Experienced User
Change the ATT modem back to router mode then configure the RBR for AP mode. You should see better speeds in AP mode.
Retired_Member
Oct 07, 2019
FURRYe38 wrote:Change the ATT modem back to router mode then configure the RBR for AP mode. You should see better speeds in AP mode.
NOT with V2.3.5.30
- FURRYe38Oct 07, 2019Guru - Experienced User
I've need no speed issues with v30 when in AP mode. Only in router mode does the WAN to LAN speeds suffer for some on v30 including prior versions of FW.
