jaybytez's avatar
jaybytez
RBK50 dropping connection with new modem Motorolla mb8611
I have been running the RBK50 with two Satellites (spoke mode) and the Motorolla MB8611 for a few years without problem.  My kids have been complaining about slowness and so I looked into changing my Comcast plan from 800mb to 900mb, and then thought about going to 1200mb and ~34 upload.  Problem is my whole house is wireless except a few items are wired.
I have all the wifi settings on and the ORBI performance reporting around 900mb and 24mb upload.  I went and purchased a mb8611, and worked with Comcast to make it my new router.  All configurations are working, but the wifi continually drops, about 10-20 times a day.  So I turned off all the wifi settings like Enable Daisy-Chain, Enable Beamforming, Enable MU-MIMO, and Enable Fast Roaming.  I turned these all off and the wifi is still dropping constantly.
Two questions:
1) If my whole house is wireless, was it even worth upgrading to gigabit speed?  My speed test is never over 900mb/24mb so I have not yet gotten even close to the advertised gb speed....so is it even worth upgrading the plan.
2) Does the ORBI RBK50 have an issue with the MB8611?  I wasn't having these drops, in fact it was rare if I had one drop in a month and now it is 10-20 times a day?
Thank you,
  • CrimpOn's avatar
    CrimpOn
    Perhaps there is a typo somewhere?
    The previous modem (not router) was an MB8611 and the new modem is an MB8611?  Was the point simply to avoid the monthly charge from Comcast?
    jaybytez wrote:
    Two questions:
    The RBR50 router internet port (WAN port) has a maximum connection speed of 1GB.  Over this Ethernet link, the maximum data throughput is 900+MB/s (in both directions).  You are indeed "close" to the advertised GB speed. Paying for more than 1GB is not going to realize any improvement.
    If there were complaints about performance when the quoted rate was 800MB/sec, then the issue is not likely to be the Comcast download speed.  Some other factor is responsible.
    • jaybytez's avatar
      jaybytez
      Thanks a ton.  Sorry, the previous modem was the Motorola MB8600.  The complaint is probably related to how I have the wireless setup and the speeds I am getting upstairs that probably degrades gaming.  So I went the route of upgrading to the MB8611, which appears to be causing connection issues with my Orbi setup.
      On the plan side, I may just downgrade my plan because I was already getting great speed, I was just trying to increase my upload speed and it doesn't get better than 24 until I go to their 1200 down plan.
      If the 8611/Orbi combo continues having issues, I may just downgrade the modem and try again.  I do have the very latest firmware on the Orbi.
      I could try running them in a daisy chain again.  I have one downstairs (the router) by a side of my house because that is where the Xfinity cable comes in.  Then I have a satellite on the other part of my downstairs and one a satellite upstairs directly above the main router.  So one router and two satellites with a sq ft of 2800.
      • CrimpOn's avatar
        CrimpOn
        I struggle to see how a standard DOCSIS 3.1 cable modem could cause WiFi interruptions.  It is probably worth a few minutes double checking the Comcast/Xfinity list of approved modems: https://www.xfinity.com/support/articles/list-of-approved-cable-modems
        Motorola's web site seems to think that it is compatible.
        https://www.motorola.com/us/mb8611/p
        Directly above is a bit ambiguous.  Generally speaking, there should be some horizontal offset between router and satellite.  There is so much hidden inside walls and ceilings that can degrade WiFi signals that it is often useful to experiment with moving satellites around a bit.  Unless there is a need to access WiFi from outside, little is gained by locating the satellite across the house against an outside wall. Half of the WiFi signal it going "out there" where it may not do anything for you.
        I would probably want to look at the Link Rates of those gaming devices and the Link Rate between router and satellites:
        root@RBR50:/# satelliteinfo wifi
            "mac address" : "A0:04:60:xx:xx:xx",
            "hop" : "1",
            "bridge mac" : "A0:04:xx:xx:xx:xx",
            "backhaul conntype" : "5GHz",
            "backhaul rssi" : "-68",
            "backhaul macaddress" : "A0:04:60:xx:xx:xx",
            "backhaul phytxrate" : "780",
            "backhaul phyrxrate" : "780",
            "backhaul parentmac" : "A0:04:60:xx:xx:xx"
            "mac address" : "14:59:C0:xx:xx:xx",
            "hop" : "1",
            "bridge mac" : "14:59:C0:xx:xx:xx",
            "backhaul rssi" : "-59",
            "backhaul macaddress" : "",
            "backhaul phytxrate" : "866",
            "backhaul phyrxrate" : "650",
