jpederson
Sep 08, 2020Aspirant
RBK50 dropping WiFi
I bought the RBK50 setup at the end of April of this year. It's worked great until the last 2 or three weeks. Now my WiFi connection is dropping constantly. I reset the entire setup and it works f...
Sep 08, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- jpedersonSep 08, 2020AspirantMy firmware is 2.5.1.16
My modem is a Horton PC20
Our house is 3500 sq ft. My router is on the second floor with a hard line to the satellite on the first floor.
I have the Ethernet from the modem to the Orbi router, then from the orbi router into a to link tl-sg108 gigabit switch. From there to the orbi satellite on the main floor.
I have the 2.5 on auto and the 5 on channel 40. The 5 was on 44 but I changed it to see if it would work. I don’t see an auto option for the 5
I have one neighbor with a WiFi signal that’s been here longer than my Orbi- jpedersonSep 08, 2020AspirantDamn auto correct. The modem is a hitron not Horton
- jpedersonSep 09, 2020AspirantI have no idea how to tell what channel my neighbor is on
The wired seems to work and it’s the router and satellite both. They’re about 25 feet apart I would guess.
This system worked flawlessly for several months. Then suddenly I have nothing. When I connect with the anywhere access on the app and my phone on cell data, it says it’s connected to the internet.
- FURRYe38Sep 09, 2020Guru - Experienced User
What channel is your nieghbor using on 2.4 and 5Ghz?
Are you having problems with the RBR or the RBS or the entire system?
Do you have wired access with a PC or laptop when the wifi drops?
