whynotme
Mar 20, 2020Aspirant
RBK50 drops to 30Mbps every couple of hours, must reboot to fix
Just installed RBK50 Orbi Triband Mesh AC3000 system and after a few hours, the speeds drop to below 50 Mbps and the only thing I can do to fix is reboot. I've now rebooted my system 5 times in 24 h...
whynotme
I should add that I'm running a brand new CM1150V modem.
Retired_Member
Mar 20, 2020I've see discussions about your modem.
Just in case...https://www.netgear.com/support/product/CM1150V.aspx
