whynotme
Mar 20, 2020Aspirant
RBK50 drops to 30Mbps every couple of hours, must reboot to fix
Just installed RBK50 Orbi Triband Mesh AC3000 system and after a few hours, the speeds drop to below 50 Mbps and the only thing I can do to fix is reboot. I've now rebooted my system 5 times in 24 h...
Mar 20, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? I would do this if you haven't.
Set the MTU value back to 1500, 1492 or less is for DSL ISP services. Cable services use 1500.
whynotme wrote:Just installed RBK50 Orbi Triband Mesh AC3000 system and after a few hours, the speeds drop to below 50 Mbps and the only thing I can do to fix is reboot. I've now rebooted my system 5 times in 24 hours. I'm running the latest firmware 2.5.1.8 and Netgear support had me set the MTU to 1492. It was set at 1500. Right after a reboot and for a few hours after I can get close to 600Mbps on my phone (Galaxy S10). Then it drops back down below 50Mbps after 2-3 hours. Anyone see this before and have a fix? Not sure what's happening to make it suddenly lose speed like that. Thanks in advance.
Retired_Member
Mar 20, 2020
FURRYe38 wrote:What is the size of your home? Sq Ft?
:smileysad:
