kmh7189
Mar 19, 2020Aspirant
RBK50 ethernet port only 100mps
So I have the RBK50 router connected to sprectrum modem (not wifi modem). i have spectrum 400mps speed. wirless out of Orbi gets 400-450mps all day long. problem is my ethernet ports only allowing 10...
- Mar 20, 2020
Ok...didn't understand đŹ
lomg story short....all pots allows up to 1gb. Problem is apparently all TVs typically have 10/100 Ethernet , and turns out my laptop also has same. When I connected my Orbi satellite via Ethernet...it was pulling the 400+MBs speeds.
CrimpOn
Mar 19, 2020Guru - Experienced User
kmh7189 wrote:So I have the RBK50 router connected to sprectrum modem (not wifi modem). i have spectrum 400mps speed. wirless out of Orbi gets 400-450mps all day long. problem is my ethernet ports only allowing 100mps best..usally 90-100mps range. i have used cat 5e, cat 6, different computers, tvs, etc and no matter what these are max speeds i get.
Very strange indeed. What connection rate shows up on the Orbi web interface, Advanced Tab Home Page, click on "Show Statistics"?
How is the speed being measured?
- kmh7189Mar 19, 2020Aspirant
getting 446mps dowonload. so i have to find a device that has a gigabyte ethernet port. seems like tvs only support 10/100.
