kmh7189
Mar 19, 2020Aspirant
RBK50 ethernet port only 100mps
So I have the RBK50 router connected to sprectrum modem (not wifi modem). i have spectrum 400mps speed. wirless out of Orbi gets 400-450mps all day long. problem is my ethernet ports only allowing 10...
- Mar 20, 2020
Ok...didn't understand đŹ
lomg story short....all pots allows up to 1gb. Problem is apparently all TVs typically have 10/100 Ethernet , and turns out my laptop also has same. When I connected my Orbi satellite via Ethernet...it was pulling the 400+MBs speeds.
Retired_Member
Mar 19, 2020firmware?
kmh7189
v2.5.1.8 updated last week is installed. i have T470 Lenovo that has 10/100/1GB ethernet port. hooked directly to orbi router port and all i get is around 100mbs. makes no sense.
- CrimpOnMar 19, 2020Guru - Experienced User
What connection rate shows up on the Orbi web interface, Advanced Tab Home Page, click on "Show Statistics"?
How is the speed being measured?
- Retired_MemberMar 19, 2020
kmh7189 wrote:v2.5.1.8 updated last week is installed. i have T470 Lenovo that has 10/100/1GB ethernet port. hooked directly to orbi router port and all i get is around 100mbs. makes no sense.
here's the problem: v2.5.1.8
