beguna1
Jul 13, 2018Tutor
RBK50 firmware update bug messes up Orbi address
When you first use the app to install Orbi, Orbi sees that there is still an existing router and gives itself a non-conflicting address. Then it installs any firmware update, and then the problems b...
Jul 13, 2018Guru - Experienced User
If you change the default IP address of the Orbi router, and you update, it may change back to the default IP address. NG always uses 192.186.1.1 as there IP address for there routers. So one thing to check for if you change the IP address to something else. Disconnect the router from all other devices accept for one wired PC. Do the update and let it install. Then check the IP address, if it's changed, then change it back to what you had it configured for, apply and reboot, then after the router is back online, re-connect everything else.
beguna1
Jul 13, 2018Tutor
I did not change the Orbi address during initial setup. The Orbi setup software did. That was smart. The firmware update should do the exact same thing or keep the changed address.
- FURRYe38Jul 13, 2018Guru - Experienced User
What did the IP address change too?
Is the Orbi connected to another router or a modem/router combo unit that uses 192.168.1.1?
- beguna1Jul 13, 2018Tutor
It automatically changed to 192.168.1.201. It is now in AP mode and is connected to a combination router/modem supplied by Google Fiber. Orbi is working great now but I wasted several hours because of the bug in Netgear's firmware upgrade software. I'm sure most people would have given up and returned it to wherever they bought it from. I was just lucky that I decided to start the setup app over again.
- FURRYe38Jul 14, 2018Guru - Experienced User
Well nobody else has reported something happening like this. I haven't seen anything like this either. I set up my friends 50 series last month and saw no IP address changes during FW updates. And I had to do a few. However his system is running in AP mode.
There will be some changing in IP addresses if you do have a Modem/router connected to the orbi system. If that modem/router uses 192.168.1.1 then it's possibe that the FW and or Setup wizard wil auto change the Orbi router to something different to avoid IP conflic as you can't have the same device using the same IP address.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.If it's working, should be fine. Maybe next time, try a update using a wired PC connected to the router with a web browser instead of the mobile app.
Enjoy.
