rp100
Nov 14, 2020Follower
rbk50 firmware update problem
I recently contacted support about my Orbi system dropping it's connection frequently. I have a RBK 50 router with one RBK 50 satellite and one RBK20 satellite. They told me to do a factory reset a...
Nov 14, 2020Guru - Experienced User
You could wirelessly connect your PC to the RBS and RBRs web page if the RBS and RBR are setup and wirelessly synce. You can connect to the RBS web page and updaete FW there, then do same on RBRs web page with a wireless PC.
USB to ethernet adapters are pretty inexpensive to get.
