meno56
Oct 12, 2023Follower
Rbk50 firmware update
Hey guys, need some advice. I have an rbr50 and two rbs50. Installed them in 2016, so they all have 1.4.x.x firmware on them. I’m trying to add a third rbs50v2 that I picked up off Amazon. It failed t...
CrimpOn
Oct 12, 2023Guru - Experienced User
meno56 wrote:
Next question, any chance the 1.4.x.x config save restoring properly on the latest version?
Updating firmware does not delete user configuration, so it should not be necessary to restore a previous config file.
Once the router is at the latest firmware release, it would be a good idea to save another config file.
