Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
pablohoney
Aug 11, 2020Luminary
Do you have version 1 or version 2 of the Orbi RBR50? I have version 1 and am still on firmware 2.5.1.16
- LiquidcoreAug 11, 2020StarVersion 2 :)
- DatabaseJaseAug 11, 2020Luminary
pablohoney wrote:
Do you have version 1 or version 2 of the Orbi RBR50? I have version 1 and am still on firmware 2.5.1.16Version 1 here. Will keep checking the two RBS50s to see if they update too.
- JgoldstiAug 11, 2020Star
My v1 rbr50 and rbs50 both updated last night to 2.5.2.4 firmware
- DatabaseJaseAug 12, 2020Luminary
DatabaseJase wrote:
Despite the RBR50 updating to V2.5.2.4 automatically both RBS50s still report V2.5.1.32 "No new firmware version available" and without the firmware files available I can't update them manually. I know Devolo push firmware based on serial number to stagger the roll out so perhaps NG do the same. Will keep looking each day to see if they update automatically too.
- FURRYe38Aug 13, 2020Guru - Experienced User
Try a factory rest on the RBR and and up from scratch. See if the set up wizard detects anything during it's run.
Check the version seen on the home page.
Be sure to clear out all browser caches.
DatabaseJase wrote:Despite the RBR50 updating to V2.5.2.4 automatically both RBS50s still report V2.5.1.32 "No new firmware version available" and without the firmware files available I can't update them manually. I know Devolo push firmware based on serial number to stagger the roll out so perhaps NG do the same. Will keep looking each day to see if they update automatically too.
