Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
SkywalkerPD
Aug 11, 2020Apprentice
My set got the update also last night. This morning my app anounced the update to me.
The firmware cannot be found on the official site.
@Netgear or maybe FURRYe38 please provide us with an changelog.
- FURRYe38Aug 11, 2020Guru - Experienced User
Sometimes NG pushes FW updates thru auto update before they post about it. I presume if NG is starting to push FW via auto update, NG will probably post it this week or next for general public. Do you see any release note information on the RBRs web page under the FW update section?
SkywalkerPD wrote:My set got the update also last night. This morning my app anounced the update to me.
- MstrbigAug 11, 2020Master
No mention of the firmware update on NG's support download page. Still shows V2.5.1.16. I just pushed a firmware check, in the GUI, and no firmware is available for update.
- pablohoneyAug 11, 2020LuminaryProbably a slow roll out...
- SkywalkerPDAug 12, 2020Apprentice
FURRYe38 wrote:Sometimes NG pushes FW updates thru auto update before they post about it. I presume if NG is starting to push FW via auto update, NG will probably post it this week or next for general public. Do you see any release note information on the RBRs web page under the FW update section?
I can't find anything on the router under the update section about release notes or what has been changed.
- clammerdsAug 12, 2020Apprentice
Mine was on the .32 and has also auto updated. Bizarrely though, it is no longer using the wired backhaul but 5Ghz despite being connected with a wire.
Either there's a bug with this firmware that prevents it using wired or it is wired and reporting wireless.Is there anyone at Netgear that monitors this forum that could give us changelog or advice on how to get wired backhaul back?
Thanks
- clammerdsAug 14, 2020Apprentice
Blanca_O netgear Any chance you could provide us with the changelog for the firmware that was automatically pushed to us?
Thanks in advance for your help
- DatabaseJaseAug 14, 2020Luminary
No further clues here either:
<Portion of post has been removed by a NETGEAR Moderator for security purposes>
The last entry is "MSG25116" which would indicate V2.5.1.16 as each of the MSG flags seem to be previous versions that I recognise.
Satellites still not updated or detecting new firmware. Hopefully something official will appear next week.
