Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
jijun1964
Aug 24, 2020Guide
Similar happen to my RBR50 and RBS50, just receive notification firmware update to 2.5.2.4, My IpTV can't connect at all. Why it heppan???
SkywalkerPD
Aug 25, 2020Apprentice
I see a firmware V2.7.0.70 mentioned in other posts now..... netgear FURRYe38 what are they doing at Netgear? :smileyfrustrated:
- FURRYe38Aug 25, 2020Guru - Experienced User
I would disregard any notifications for v70 version. Nothing has been posted about it and seems to have cuased problems for others that loaded it thru the Orbi app. Even v4 hasn't been posted officially and not sure if it will. Just someone posted the auto update server links to it for those who wanna try it, unofficially.
Official supported released FW is v16 currently seen on NG update page. I recommend that users keep this loaded and avoid loading of anything else until such time as you see something new on NGs download web page.
SkywalkerPD wrote:I see a firmware V2.7.0.70 mentioned in other posts now.....what are they doing at Netgear? :smileyfrustrated:
