Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
Almighty
Sep 30, 2020Tutor
I installed 2.5.2.4 yesterday and have had some wifi drops and a lot of connected devices are not showing as connected.
Also tmy satellite doesn't show device name just "unknown"
Any one else having these issues?
Sep 30, 2020Guru - Experienced User
Has a power off for 1 minute then back on been performed since last update?
Almighty wrote:I installed 2.5.2.4 yesterday and have had some wifi drops and a lot of connected devices are not showing as connected.
- AlmightyOct 01, 2020Tutor
Yes. Powered it down for approx 5 min.
Still missing a lot of devices and all devices on the satellite are "Unknown"
- MstrbigOct 01, 2020Master
Almighty wrote:Yes. Powered it down for approx 5 min.
Those are the ones that you will probably have to go to directly and forget the network and re-join, then reboot
Also update the firmware to the latest 2.7.0.70
