Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
Sep 30, 2020Guru - Experienced User
Has a power off for 1 minute then back on been performed since last update?
Almighty wrote:I installed 2.5.2.4 yesterday and have had some wifi drops and a lot of connected devices are not showing as connected.
Also tmy satellite doesn't show device name just "unknown"
Any one else having these issues?
Almighty
Oct 01, 2020Tutor
Yes. Powered it down for approx 5 min.
Still missing a lot of devices and all devices on the satellite are "Unknown"
- MstrbigOct 01, 2020Master
Almighty wrote:Yes. Powered it down for approx 5 min.
Those are the ones that you will probably have to go to directly and forget the network and re-join, then reboot
Also update the firmware to the latest 2.7.0.70
- AlmightyOct 02, 2020Tutor
I have restarted a couple of devices but they are not shown in connected list.
Also none of the wires devices are showing either.
A lot of wifi devices are dropping connection.
The firmware updates of Orbi RBR50 is really bad.
It shouldn't be this many issues every time a new FW is released.
- mrfrancOct 02, 2020Apprentice
Update the firmware to the latest 2.7.0.70
