Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
Almighty
Oct 01, 2020Tutor
Yes. Powered it down for approx 5 min.
Still missing a lot of devices and all devices on the satellite are "Unknown"
Mstrbig
Oct 01, 2020Master
Almighty wrote:Yes. Powered it down for approx 5 min.
Those are the ones that you will probably have to go to directly and forget the network and re-join, then reboot
- MstrbigOct 01, 2020Master
Also update the firmware to the latest 2.7.0.70
- AlmightyOct 02, 2020Tutor
I have restarted a couple of devices but they are not shown in connected list.
Also none of the wires devices are showing either.
A lot of wifi devices are dropping connection.
The firmware updates of Orbi RBR50 is really bad.
It shouldn't be this many issues every time a new FW is released.
- mrfrancOct 02, 2020Apprentice
Update the firmware to the latest 2.7.0.70
- FURRYe38Oct 02, 2020Guru - Experienced User
Be sure to power OFF the ISP modem, RBR and RBS for 1 minute then back ON after a FW update. If problems still crop up, a factory reset and setup from scratch maybe needed.
Almighty wrote:I have restarted a couple of devices but they are not shown in connected list.
- AlmightyOct 04, 2020Tutor
How the hell can a restart of my fiber switch have anything to do with my Orbi not showing my connected devices?
If I reboot/shutdown the Orbi units all connections are dropped and the Orbi router has no idea if any other node has been restarted.
But just for taking your advise I will do as you what you say.
