Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
Mstrbig
Oct 01, 2020Master
Almighty wrote:Yes. Powered it down for approx 5 min.
Still missing a lot of devices and all devices on the satellite are "Unknown"
Those are the ones that you will probably have to go to directly and forget the network and re-join, then reboot
Mstrbig
Oct 01, 2020Master
Also update the firmware to the latest 2.7.0.70
