Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
Almighty
Oct 02, 2020Tutor
I have restarted a couple of devices but they are not shown in connected list.
Also none of the wires devices are showing either.
A lot of wifi devices are dropping connection.
The firmware updates of Orbi RBR50 is really bad.
It shouldn't be this many issues every time a new FW is released.
Oct 02, 2020Guru - Experienced User
Be sure to power OFF the ISP modem, RBR and RBS for 1 minute then back ON after a FW update. If problems still crop up, a factory reset and setup from scratch maybe needed.
Almighty wrote:I have restarted a couple of devices but they are not shown in connected list.
