Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
Mstrbig
Oct 14, 2020Master
COMountainGoat wrote:Yup, badly borked - the connected device page is completely inaccurate. Logging into the satellites shows local connections, but even those are incomplete.
Downgrading to 2.5.1.16 is the answer.
Netgear *really* needs to give us a UI option to disable firmware updates that persists across reboots.
Actualy if you wait 24 to 48 hours, the system seems to stablize and everything seems to correct itself in the app and GUI, with the exception of maybe a cellphone and camera or 2, which just needs to have the network forget and rejoin routine.
Problem is everyone is impatient and downgrades too quickly.
The better solution would be to manually upgrade to V2.7.0.77. Just remember to update the satellites first, then the router. I upgraded 3 RBK53 systems this morning to 2.7.0.77, with no issues.
I find, after updating, I see better speeds on any ISP over 350Mbps and smoother and faster connections.
COMountainGoat
Oct 17, 2020Apprentice
Even if waiting worked (which from other reports, it doesn't), waiting hours or days for a network appliance to correctly report attached devices isn't acceptable. Full Stop.
It appears that the SDLC for Orbi Firmware consists of:
1) Does it compile? Yes -> Ship it
With little to no QA or regression testing. Seriously, something as basic as attached devices breaking wasn't caught?
If the radio's weren't so darn good, I'd dump the system. As it is I'm very tempted to blackhole the Netgear update servers so it can't ever auto-update.
- FURRYe38Oct 18, 2020Guru - Experienced User
Users can revert to v16. v16 seems to work well for stock FW. Havn't had any problems using this version.
User can also use Voxe's 3rd party FW as well:https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you.
Good Luck
