Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
ReneK
Nov 15, 2020Aspirant
Installed the new 2.5.2.4 software on base and satellite. Wish I hadn't because now I can't access the 'Advanced' settings anymore on my Orbi. Anyone else with this problem?
- argoldNov 15, 2020Guide
Firmware V2.5.2.4 has not affected my access to the Advanced menu including Advanced Setup.
- ReneKNov 15, 2020Aspirant
Found it! It is Safari in Big Sur (MAC-OS) that's blocking the advanced page...
More to read on:
- FURRYe38Nov 15, 2020Guru - Experienced User
Try a different browser?
ReneK wrote:Installed the new 2.5.2.4 software on base and satellite. Wish I hadn't because now I can't access the 'Advanced' settings anymore on my Orbi. Anyone else with this problem?
- GeblaDec 08, 2020Apprentice
I had to move back to 2.5.1.16. On this release a wired connected device suddenly looses internet connection. I can still browse the internal network but external no longer possible.
- FURRYe38Dec 08, 2020Guru - Experienced User
v4 has been preceeded by v40 now. v4 is now out of date so if you wanna try v40 later on:
Otherwise keep what works for you. V16 is stable IMO.
Gebla wrote:I had to move back to 2.5.1.16. On this release a wired connected device suddenly looses internet connection. I can still browse the internal network but external no longer possible.
