Liquidcore
Aug 10, 2020Star
RBK50 Firmware Version 2.5.2.4?
Hi all, I woke up this morning with a notification from the Orbi app that the firmware on my RBK50 had been automatically updated to 2.5.2.4 (screenshot attached). There doesn't seem to be any ment...
Nov 15, 2020Guru - Experienced User
Try a different browser?
ReneK wrote:Installed the new 2.5.2.4 software on base and satellite. Wish I hadn't because now I can't access the 'Advanced' settings anymore on my Orbi. Anyone else with this problem?
Gebla
Dec 08, 2020Apprentice
I had to move back to 2.5.1.16. On this release a wired connected device suddenly looses internet connection. I can still browse the internal network but external no longer possible.
- FURRYe38Dec 08, 2020Guru - Experienced User
v4 has been preceeded by v40 now. v4 is now out of date so if you wanna try v40 later on:
Otherwise keep what works for you. V16 is stable IMO.
Gebla wrote:I had to move back to 2.5.1.16. On this release a wired connected device suddenly looses internet connection. I can still browse the internal network but external no longer possible.
