kitng98
Dec 12, 2019Aspirant
RBK50 hardwired to RBS50 ??
Question:
Is it ok to connect my RBS50 (Router) to my RBS50 via ethernet cable ?
does that make the RBS50 behaves like an Access Point ???
Will it extend my WiFi ranges/reaches ?????
thanks
1 Reply
RBS50 is a satellite. not a router.
If you are asking if you can use a wired backhaul to connect a RBR50 to a RBS50 then the answer is yes. It works great and I've done it with mine. You can even daisy chain the satellites with the wired backhau.
