TLane1957
Jan 08, 2019Tutor
RBK50 how do I change my IP Address
My IP address on my router is 10.0.0.1 and I need to change it to a 198.168.0.1 IP address. How can I do this?
Thanks,
Tony
st_shaw
Jan 08, 2019Master
Log into the router GUI at http://10.0.0.1 and change the LAN settings there to whatever LAN IP range you want to use. See Advanced, Setup, LAN Setup. Note that you cannot use the same range that's assigned to Orbi's WAN port. You can find Orbi's WAN IP in the GUI also.
If your router is using 10.0.0.1 on its own, it usually means you are running Orbi behind another router and that other router assigned a private address, e.g. 192.168.1.X address to Orbi's WAN port. In that case you would be double NAT'd and would likely be better off running Orbi in access point mode.
michaelkenward
Jan 09, 2019Guru - Experienced User
It might help to clarify this bit by telling us the make and model of the device in front to the Orbi router.
- TLane1957Jan 09, 2019Tutor
Thank you for the feedback. The device in front of my Orbi router is a Motorola cable modem. The model number is MB8600. My internet provider is Xfinity but this is not their router.
- michaelkenwardJan 09, 2019Guru - Experienced User
That is a modem/router. Look at all those LAN ports on the back.
Two routers on your network can cause headaches. For example, you can end up with two DHCP servers and that can create local address conflicts. Among other things, this can mean that trying to get at addresses like routerlogin.net or the usual IP address for a router, 192.168.1.1, gets misdirected by the other router.
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
Sometimes it is possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. But some Internet service providers, such as BT in the UK, supply customers with a modem/router that just won't work in bridge mode. There may be ways to get the device to cooperate, but sometimes it is just easier to put the second router in AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportThe Motorola manual tells how how to use this with a router.
www.motorolacable.com/documents/MB8600-QuickStart.pdf
See the section If You Want To Connect a Router.
Life would probably be easier if you did that.
- st_shawJan 09, 2019Master
If your statement is based solely on how the device looks, then you should double check that. I read a review of the MB8600 earlier today and the review stated the device was a modem only, and that the multiple LAN ports were there only for future support of bonded connections > 1 GBps.
