TLane1957
Jan 08, 2019Tutor
RBK50 how do I change my IP Address
My IP address on my router is 10.0.0.1 and I need to change it to a 198.168.0.1 IP address. How can I do this?
Thanks,
Tony
Jan 09, 2019Guru - Experienced User
Motorola supports this modem as a modem only. There current support site shows just the WAN port, however the yellow is covering additional ports which maybe for future needs or ISP that support thhis model modem/router combo:
https://motorolanetwork.com/mb8600.html
The Orbi is using a 10.0.0.1 on the LAN side, so this means that the orbi probably detected a /modem/router using 192.168.1.1 on the WAN port and changed to 10.0.0.#. You can still change from 10 to 192.168.0.1 since this doesn't conflict with what the Orbi is dectecting from the router in front of the Orbi.
Modem Combo Units:
Couple of options for future reference,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thanks,
Tony
