Kmaan
Aug 24, 2018Aspirant
RBK50 how do I keep separate passwords for 2.4 GHz and 5 GHz through telnet
Hello Orbi friends,
I have a RBK50 and two RBW30 connected together to form a mesh system. Due to the evergreen wifi dropouts we've been hearing for a long time, I decided to separate the 2.4 ...
Kmaan
Aug 29, 2018Aspirant
Hello FURRYe38,
For some reason, your reply is trimmed in the forum. I checked the other link in your response and unfortunately it doesn't tell anything about changing the passwords.
Aug 29, 2018Guru - Experienced User
Well the link is for splitting the single SSID and having each radio have its own SSID and PW. Something that NG doesn't support. The Orbi is based and designed on a use of a single SSID and PW for use with both frequencies.
- KmaanAug 29, 2018Aspirant
Thanks, as I mentioned in my initial post I separated the SSIDs, but just want to keep separate passwords for both. I suspect there is some command that we can utilize through telnet to set that, haven't got any luck though!
- FURRYe38Aug 29, 2018Guru - Experienced User
So nothing in that link about inputting a PWs for each radio?
Maybe there isn't. You might post in that thread and ask...
