ajbacon
Jul 02, 2020Aspirant
RBK50 Intermitent Wi-Fi issues
Last year I bought a RBR50/ RBS50 Router/ Mesh Kit from Amazon (the RBK50 kit). I decided to update the firmware last year and the result was intermitent wi-fi from the RBR50. I have tried all the po...
Jul 02, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz. 2 should not be used.
