P95357
Mar 18, 2019Guide
RBK50 internet connection issues with iOS devices (and now Dell Latitude laptop computers as well)
Dears,
I wonder if you could help me as I'm running out of hope and patience here. The experience seems very similar to chrystal meth. Orbi gave me that first fix which was fantastic. It was fa...
- Apr 30, 2019
I would manually download the v48 files, re-load the RBS's first, then the RBR, then factory reset and setup from scratch. Use a wired PC, and IE11 or Firefox or Opera browsers for this process. Once you get the system setup again, do a back of of the configuration to file for safe keeping.
P95357 wrote:
And then I updated via the app to Firmware Version 2.3.1.48. And the Orbi router is offline ever since.
What a pain in the ass this system is. They never heard of set and forget. You need to buy into a brotherhood to survive.
Any ideas before I give up and try another brand?
P95357
Apr 29, 2019Guide
Apr 30, 2019Guru - Experienced User
- P95357Apr 30, 2019GuideDone. Factory reset with the paper clip on the router did the trick. It took me 2,5 hours with Netgear’s support on the phone but I finally have the main router and the 2 satellites online again.
I don’t think I’ll update the firmware anytime soon.
Thanks for your support. - FURRYe38Apr 30, 2019Guru - Experienced User
Glad you got it working. FInally.
Enjoy. :smileywink:
