NoNo_BadDog
May 20, 2018Star
RBK50 IPv6 Stops Working
About every 24 hours IPv6 stops functioning on my system. Verified via http://ipv6-test.com. I have to login and click apply in the IPv6 setting and it starts working again for about 24 hours. I h...
May 21, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem the orbi is connected too?
Try a full reboot of the router and test again. If it still happens, try a full factory reset of the router and set up from scratch...
- NoNo_BadDogMay 21, 2018Star
The modem is an Arris TM822 and IPS is Comcast. I will try a reboot and monitor. If it happens after rebooting I will do a factory reset.
- FURRYe38May 21, 2018Guru - Experienced User
Is the modem bridged or a stand alone modem? Not built in router. The TM822 comes in a TM822g which has a built in router...
- RocketSquirrelMay 21, 2018Luminary
My ISP is Comcast and I am also failing to connect to any sites via IPv6 today. Rebooted everything and v6 is still down.
I think Comcast may be having an outage.
My modem is a new Motorola MB8600.
I tried rebooting. IPv6 did not come back. I factory reset the sat and router and reconfigured manually, not from backup file. Tried both "Get Automatically from IPS" and manually configuring Google IPv6 DNS addresses. Still no IPv6.
I connected directly to my modem via Eth cable. IPv6 works.
Something must be wrong with the Orbi. I guess the next thing to try is back reving the FW?
- JoechangJan 09, 2019Apprentice
I have seen your thoursands of reply repeting rebot and factory reset, pls stop and it deesnt work 100%
- michaelkenwardJan 10, 2019Guru - Experienced User
Maybe not for you but it does work for some %.
Feel free to ignore messages that do not apply to you but that may help other users.
